rear corner parking sensor advice?
Old Sep 29, 2016 | 04:54 PM
philwarner's Avatar
Default rear corner parking sensor advice?
I have a non functioning right rear parking aid sensor as the result of someone hitting the rear bumper cover in a parking lot sometime. I bought a used sensor and have read that it can be changed by removing the tail light and replacing it by feel. I'd appreciate any advice on how to release the old one from whatever holds it in the bumper cover and photos would really be helpful. I suppose it could be just the connector, but won't know until I get a hand in there and I don't expect to be that lucky.
I had my front bumper cover off to chase a coolant leak and wish I had paid attention to how the front ones were attached (assuming the rear are held the same way) but unfortunately I didn't and I don't want to break any high dollar clips. Any advice will be appreciated.
BTW, the coolant leak appears to be gone and both electric pumps are now operational, so it was worth all the trouble and we should be set for the cold weather to come.
Old Oct 15, 2016 | 12:04 AM
06-XJR's Avatar
How did you make out with this? I have to replace the left rear sensor on my car.
Old Oct 16, 2016 | 04:38 AM
clifton94's Avatar
The sensor is held in by two little fingers one each side you just ease them to one side as you push the sensor out from the outside if you have big hands just take the bumper off and then you can clean out all the stones trapped in there
kmeseck
Sep 13, 2017 09:25 AM
sogood
Sep 20, 2016 02:18 PM
Aalkul
Sep 1, 2016 10:17 AM
BC XJS
Aug 31, 2016 01:43 AM
