Rear entertainment Electrical
I have a 2008 JX-VDP with RES. The car was in a flood so there was some electrical issues that have all been crrected except the RES. My delaer has replaced the resar control module, the DVD player, The electronic module in the trunk and the RES Module behind the back seat. Still no vvideo or sound. The Rear arm rest control gets power but not feed from the DVD. The DVD appears to be operating by taking and ejecting a DVD. Is ther any way I can tell if the Arm rest control is getting the right signals and/or if it also need to be replaced. I was looking for a schematic to check if I was getting viltage where I need it but the video signal is something different. any ideas???
I've had my rear console out once, but I don't know if I can help you. New modules sometimes have to be 'programmed' using SDD. Do you know if the dealer did that?
Do you get sound from the system besides the RES and DVD...like radio, CD, and Changer?
Even if the DVD player isn't working, you should be able to put a video source into the rear armrest and show it on the headrest screen. Audio should be the same... an audio source into the L and R RCAs should play directly through the amplifier. Are those working?
Would you like the electrical schematic of the RES...would that help ya?
99xk8guy
Sep 29, 2025 10:51 PM
