Reconnecting a battery after a period of disconnection
Old Jul 31, 2024 | 10:18 AM
general_piffle's Avatar
Default Reconnecting a battery after a period of disconnection
I have an XJR 1996 and in an attempt to stop it going flat have disconnected the negative terminal of the battery, as I’ll be away for a few months.
Is there anything specific I need to do on my return, when reconnecting it?
Thanks in advance.
Old Jul 31, 2024 | 10:51 AM
NBCat's Avatar
If the vehicle is being stored near an electrical outlet, it would be better to use a battery maintainer that disconnecting a terminal.
Once the battery is disconnected, all the emissions monitors and other learned settings are going to need to be reset whilst driving through a specific cycle under certain conditions.
Old Jul 31, 2024 | 10:55 AM
It’s not anywhere near a supply. As long as the car will relearn those settings itself through use then I’m fine with that. Thanks.
Old Jul 31, 2024 | 11:49 AM
Six Rotors's Avatar
If you care about battery life, the battery should be fully charged before you disconnect it and should be charged every 3 months as a minimum. It should be stored in cool conditions. The longer you leave the battery without recharging the shorter will be its remaining life.
If it was my battery I would remove from the car and store in my garage/basement on a battery charge maintainer
Old Jul 31, 2024 | 11:54 AM
Thermite's Avatar
I'd suggest Solar chargers, decent ones DO work well enough....
But I'd guess you are garaging it under cover!!
For the even electrically-foolisher 2011 L320, If I couldn't make use of 'any of the above' I would add a fair-sized "deep-discharge" Marine/RV battery in parallel.
Old Jul 31, 2024 | 02:16 PM
motorcarman's Avatar
Probably get more exposure if you posted in the appropriate forum section.(this is the 'big aluminum car' section)
Dr dome
Jan 27, 2024 08:29 AM
GeaBaldyVx
Jun 14, 2022 08:32 PM
Lizard
Dec 21, 2021 09:59 AM
Dpk2313
Nov 13, 2013 08:38 AM
jjf
Sep 16, 2012 10:56 PM
