Removing glove box
Old Dec 5, 2023 | 11:12 AM
Andyzjag's Avatar
Default Removing glove box
Hi, I am replacing a failed glove box door latch/actuator and need some advice (no luck on a forum search). So far, I have removed the wood panel above the glove box, as well as the passenger side air vent, but it appears I need to remove the glove box liner as well. I have removed the 2 Torx fasteners from inside the glove box, as well as every Phillips head screw I could see, but the glove box is still reluctant to come out. What am I missing? Thanks in advance for any help. Andy
Old Dec 5, 2023 | 11:31 AM
clubairth1's Avatar
Community Influencer
As always doing some searches helps a lot?
Here is one that was easily found?
Glove Box Removal
Here is one on glove box door repair as they do come apart sometimes.
Glove Box Door Repair
Old Dec 5, 2023 | 10:11 PM
Andyzjag's Avatar
Thank you!
Abacab
May 9, 2025 02:51 PM
Glendoramike
Oct 9, 2024 04:11 PM
Timeisrelative
Jul 6, 2019 02:40 PM
sws805
Dec 14, 2012 09:36 PM
patrick12
Jun 1, 2009 05:35 PM
