Replacing air compresser
Old Jun 18, 2020 | 08:34 AM
Estam's Avatar
Default Replacing air compresser
Good morning, I am having to replace my suspension air compressor on a 2005 vdp and would like to know if it is ok to drive on the road without air in the shocks.
Many thanks...
Old Jun 18, 2020 | 09:16 AM
Now you've reposted the question here in X350 forum, I've removed your earlier version from X351 forum.
Old Jun 18, 2020 | 11:53 AM
Fraser Mitchell's Avatar
"would like to know if it is ok to drive on the road without air in the shocks."
No, it's not, but there is a valve in each shock that retains a minimum of air pressure. This is done to make it very difficult to rotate top in relation to bottom and thus damage the air diaphragm. This feature also means the car will always have at least some pressure, so you wouldn't be on the bump-stops. However this assumes your shocks hqve no leaks, because obviously a leak bypasses this valve. Having said all this, I would not drive the car on the road at any kind of speed without the full air suspension system in operation.
Old Jun 18, 2020 | 12:08 PM
Estam's Avatar
That's great, thanks for the info, I'll call for a flat bed when it's time.
There are no bumps to worry about in this area, clearance doesn't look bad but cant be sure.
Regards,
Old Jun 19, 2020 | 02:15 PM
Wingrider's Avatar
R M T has new compressors for under $200 delivered.
At that price i bought two,installed one in my 04, works great.
Put the other one on the shelf
Old Jun 20, 2020 | 08:22 PM
Wingrider's Avatar
Not a hard job, to do yourself
Old Jun 22, 2020 | 10:05 AM
Don B's Avatar
Many thanks...
Hi Estam,
How did you confirm the compressor required replacement? Did you rule out the air suspension relay?
If the compressor motor runs but the compressor does not pressurize the system adequately, you can often restore its performance with an inexpensive piston ring/seal kit from our member bagpipingandy (bagpipingandy.com).
Cheers,
Don
Old Jun 22, 2020 | 11:59 AM
Wingrider's Avatar
Rebuilt mine & got a couple more years from it.
But at $200 delivered for a new compressor, is the old one worth rebuilding?
Old Jun 22, 2020 | 12:41 PM
Don B's Avatar
If the old cylinder head is in good condition, you can save your German/European-made Wabco compressor, and I've had excellent long-term success with the compressors I've rebuilt (no failures yet since 2014).
On the other hand, more recently, for a couple of cars with seized compressor motors whose owners didn't want to spend much money, I've installed the cheap $150 China-made compressors from eBay. So far so good, but who knows how durable those motors are, or the quality of the metal alloys or piston ring/seal?
Cheers,
Don
Old Jun 22, 2020 | 02:57 PM
Wingrider's Avatar
These are NEW, made by R M T, with a lifetime guarantee.
Old Jun 22, 2020 | 03:12 PM
Don B's Avatar
The $150 pumps on eBay are also new, with at least a limited warranty, but the lifetime guarantee on the R.M.T. compressors is certainly appealing.
Old Jun 22, 2020 | 04:40 PM
I had to have a compressor replaced on my first X350, a 2003, shortly after I bought it in 2010. I had a service-exchange unit fitted by the nearest Jaguar main agent, Royles of Wilmslow. This cost me about £300 at the time and I was a bit miffed because whilst the car was 7 years old, it had only done 35k miles. Yet the replacement compressor was still on the car and working well at 115k miles when I traded the car for another X350, an X358 Sovereign. Wabco made these compressors, and I believe they had to make changes because many Jaguar owners needed new compressors within the warranty period ! I should say that it wasn't only air compressors that regularly failed inside the warranty; the suspension arm bushes were notorious for their short life, and no improvements were ever made for these. It was the continuous repair burden with the suspension components on the car that finally decided me to get an XE and trade in the XJ. Yes, I am probably paying much more in depreciation than I would have ever spent on repairs, but at least the car isn't in the workshop every month ! And this time I have a Jaguar warranty.
Old Jun 22, 2020 | 05:19 PM
Wingrider's Avatar
Don B said;
That's what i thought, & at $182.16, plus tax, with free delivery, was a good deal.
Old Jun 25, 2020 | 12:22 PM
clubairth1's Avatar
Community Influencer
Watching to see if these new lower cost pumps hold up. None reported failed yet on the forum??
If they do it will be a great thing compared to the very high price from Jaguar.
I am currently rebuilding one using Andy's kit but the pumps are getting up in years and the number of hours on them.
Old Jun 25, 2020 | 02:58 PM
Wingrider's Avatar
The issue with mine was the bore was scared up pretty badly.
The new piston ring would work better & last longer if was in better shape.
Old Jun 25, 2020 | 03:08 PM
JX350's Avatar
I second Don B's comment about the piston seal kit. I did mine and it only took about an hour to do the whole job including getting the compressor out and refitting it. Very easy and only cost £25. I replaced mine due to air suspension faults especially when the car was cold or driving up an incline. I replaced mine nearly three years ago, about 64K miles in total, and the suspension has been fault free ever since.
Nalahung
Sep 26, 2017 11:40 PM
rf69
Sep 5, 2016 10:37 AM
Rickkk
20
Mar 31, 2014 04:36 PM
msjam
Mar 14, 2011 03:29 PM
