replacing thermostat housing
Old Jun 25, 2013 | 01:40 AM
slmskrs's Avatar
From: San Francisco Bay Area (south bay), California USA
Default replacing thermostat housing
I've got the new replacement thermostat housing which includes the thermostat, thermostat cover, temp sender, etc.
However, I can't see how the big open end opposite the thermostat will connect/seal to wherever it goes (if you look at the attached, it is the opening right where the number 16 is).
There's no seal on the edge or inside, yet coolant definitely flows there, so it has to be connected/sealed to something (into the intake manifold?).
Please help. I want to make sure I have all the parts I need before I start working on this, and since I see no seal, etc., I'm concerned I'll pull the old one off and find out that I need some sort of seal, etc.
Any and all help appreciated.
Thanks,
Gordon
Old Jun 25, 2013 | 06:02 PM
meirion1's Avatar
Have you got JTIS? ie workshop manual.
It's not very good but better than nothing.
Old Jun 26, 2013 | 02:56 AM
caldoofy's Avatar
There is a seal shown on your attached image it's directly below number 18 and fits into a groove in the thermostat housing sealing when joined . Fitted a new one when I changed mine.
Old Jun 26, 2013 | 07:49 AM
Brutal's Avatar
no he's talking about the neck that goes down and bolt to the engine just below the front of the engine. This piece needs to be replaced to and it has the large 1/4"oring seal on it. You replace that piece on the engine first, then put the intake metal elbow back on and the the rest of the t sta housing and vaseline to opening to help slip it on
Old Jun 26, 2013 | 01:29 PM
slmskrs's Avatar
The only think I see under 18 is the seal for the thermostat. Sorry I'm so lame, but I don't see anything that seals/fits behind the housing (right where the arrow to #16 is). That end has to seal up to something, and I don't know what that is or how it seals. And I don't want to take it apart and then find out I'm missing some stuff. The 6000 page service manual is no help (at least I can't find it).
Attached Thumbnails replacing thermostat housing-screen-shot-2013-06-26-11.25.45-am.png
Old Jun 26, 2013 | 01:53 PM
Brutal's Avatar
Sigh......in your full pic 23 is the seal and 24 is the neck i refferred to already
Old Jun 26, 2013 | 02:01 PM
caldoofy's Avatar
I thought you were referring to the t stat seal but as already mentioned by Brutal the seal you need is on your full diagram (the reason i said t stat seal in the first place being that it had centred in on that area).
Old Jun 26, 2013 | 05:39 PM
slmskrs's Avatar
Thanks guys!! Now it makes sense. From the diagram, it doesn't look like 23 and 24 mate to the opening where 16 is, but I just went to the garage, and voila! It fits. I couldn't figure out how/where 23/24 went (when I looked at the replacement). Thanks for the tip on mounting it first and using some vaseline Looks like I got all I need (other than I'm still struggling on finding all the hoses I need. The two coolant reservoir hoses are out of stock at APW. It looks like one is the "coolant vent hose". But since I'm sure the local dealer will rape me on price and this hose is easy to get to, I'll probably just get it at Jaguar Parts Center since it is easy to get to and replace at a later time. There are several additional hoses that connect to some sort of "valve" on the throttle body and I can't for the life of me find them in any diagram, nor locate any of them (by part number) on the web. So something I'll probably have to go to the dealer for.
Hopefully in a week or two this new-to-us car will have everything done (preventive maintenance) so there's no question as to whether something might not have been taken care of (since it all will have been). Looking forward to it (getting everything done....
Doug
Feb 27, 2019 01:31 AM
KarimPA
Sep 12, 2015 08:15 AM
obwoodie
Sep 3, 2015 07:45 PM
Joey T
Sep 3, 2015 05:31 PM
d a
Sep 3, 2015 02:34 AM
