Restricted performance
Old Dec 1, 2012 | 02:22 PM
Gribblet's Avatar
Default Restricted performance
2004 XJ8 4.2
Car is showing the following codes
PO351 Ignition Coil A
PO354. Ignition Coil D
PO356. Ignition Coil F
PO357 Ignition Coil G
P1367 Ignition System Failure
Car got wet underneath, any suggestions?
Old Dec 2, 2012 | 12:38 AM
randyshear's Avatar
If it got wet you will want to pull the ignition relay and maybe swap it with another relay. Check the ignition fuse as well... Maybe the water shorted something temp and now it is dry?
Old Dec 2, 2012 | 04:21 PM
meirion1's Avatar
Member on the UK forum found blocked drain below windscreen and suspects ECU flooded, this a known possiblity.He had P1367 also.
Delta66
Oct 4, 2015 05:40 PM
Johncy2000
Oct 2, 2015 01:05 AM
1100me
Oct 1, 2015 11:49 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
