Reverse Parking Aid System - Disable Button Location
Old May 3, 2014 | 08:56 PM
abonano's Avatar
Default Reverse Parking Aid System - Disable Button Location
Hi Guys,
My 04 XJ8 - G31389 has the reverse parking sensors. Now one would think the disable button would be located in the upper console.
To my surprise - there is no such button. My question is: would this disable button be located elsewhere? To note - every X350 I have come across w/ the parking aid system has the disable button located in the overhead console.
The system is currently working despite the lack of a disable button but the system was acting up a few weeks back and I wanted to disable it for the interim. (WDS code for "short to ground")
I suspect the previous owner replaced the upper console w/ a replacement that didn't have the reverse parking aid reverse button.
(Looks like I'm going to find a used upper console and get this sorted)
Any feedback would be appreciated - thanks!
Old May 3, 2014 | 10:05 PM
Rufus T. Firefly's Avatar
I may be wrong, but I thought the disable button on the overhead was only installed when front AND rear sensors were installed. Not for when just rear.
Rufus
Old May 3, 2014 | 10:19 PM
Cambo's Avatar
Yes that's correct, if you only have rear sensors then you can't turn them off, well you couldn't in my old X-Type, which was only rears...
Old May 4, 2014 | 05:32 AM
meirion1's Avatar
To disable rear sensors you can pull a fuse located in boot fuse box.
Fuse no is listed in the driver's handbook.
Old May 4, 2014 | 10:21 AM
abonano's Avatar
Thanks guys for the responses.
This was driving me batty as my 00 S Type (w/ rear sensors only) has a disable button in the upper console.
It's working for now (hopefully it continues to) so I won't have to pull the fuse.
The existence of a disable button somewhere in the interior was sparking my interest.. as you can see I'm still learning about my newest acquisition...
FrickenJag
Jun 16, 2025 02:15 PM
afterburner1
Dec 16, 2015 12:12 AM
tberg
Sep 7, 2015 07:32 AM
mcdutch
Sep 4, 2015 03:38 AM
