Ride height question
Old Dec 25, 2012 | 02:56 PM
raschwar's Avatar
Default Ride height question
My '06 XJR rides about 1/2 inch higher in the back. When I unlock the door the car attempts to level but stops at this point. I just replaced the front struts and had to remove the height sensors in the process. I don't know how it sat before the change.
Shouldn't the car sit level front to back?
thanks
Old Dec 25, 2012 | 04:53 PM
reyesl's Avatar
Ride Height Specs:
Front: 386mm (+ - 15mm)
Rear: 373mm (+ - 15mm)
Old Dec 26, 2012 | 05:59 AM
Fraser Mitchell's Avatar
Sounds like the ride heights need calibrating again after the repairs.
This is done using the diagnostics socket and a PC with the relevant program. Vehicle height can be raised and lowered from the PC and when the height measurement is correct, this is confirmed to the air suspension control so it knows the values to expect from the ride height sensors. Car first has to have the correct weight from the definition, but I'm not sure what this is, probably vehicle empty with a full tank of fuel.
GordoCatCar
Jan 2, 2017 01:10 PM
ZJag
26
Sep 5, 2016 03:33 PM
chatmanx
Sep 11, 2015 07:17 PM
Quebecjag
Sep 10, 2015 06:06 AM
mhamilton
US Lower Atlantic
Sep 4, 2015 05:00 PM
