Rough idle with AC on
Old Jul 25, 2023 | 05:12 PM
Kennyk's Avatar
Default Rough idle with AC on
Hello everyone, I have a 2005 XJ8 with a rough idle when I turn my air conditioning on. This has been getting progressively worse since last year. I try not to use the air conditioning now because of this issue. I have cleaned the throttle body already last week and it did not help. The throttle body itself is relatively new. I replaced it last year. I did hear about the IAC valve going bad but I haven't seen anywhere on the web that says my particular model has one. I did see that the older XJ8s have one but not the x350s. Looking for any advice. Thank you!
Old Jul 25, 2023 | 06:54 PM
h2o2steam's Avatar
A thought out of left field here ........might pay to check your grounds.
Particularly G26 rear of RHS shock tower, G3 under the front power distribution box and G7 left side of the transmission tunnel (inside cabin).
Old Jul 25, 2023 | 08:16 PM
Kennyk's Avatar
Great advice I will check those grounds thank you
iramphal
Aug 12, 2020 03:26 PM
JagfanNYC
Jul 17, 2012 09:53 AM
The Coupe
Mar 28, 2012 08:00 PM
fastnboulbous
Mar 23, 2011 08:29 AM
MTW
Aug 28, 2010 04:46 PM
