Rubber or neoprene seals for intake to head
Old Nov 2, 2018 | 02:55 PM
westway's Avatar
Default Rubber or neoprene seals for intake to head
I have a 2004 Vanden Plas I cant find the 8 formed seals for this car. Everywhere I look the application only goes up to 2003. Is it possible those seals arn't applicable for 2004 and up? When I look on line for Intake sets it only has the two gasket. If they are applicable is there an aftermarket supplier?. Tried ebay, Parts geek, Amazon, Rock Auto so far nothing. They all show the 8 seals in blue up to 2003. My mechanic says they are green. TIA for any help . Pictured are the up to 2003 application
Old Nov 2, 2018 | 04:16 PM
Wingrider's Avatar
Not the ones that my 2004 XJ8 used
Old Nov 2, 2018 | 05:28 PM
Box's Avatar
Box
https://www.ebay.com/itm/jaguar-xj8-...%7CModel%3AXJ8
Old Nov 3, 2018 | 04:37 AM
Wingrider's Avatar
Those look like the ones you need, for less than i paid, by a few dollars, over a year ago.
Old Nov 3, 2018 | 01:19 PM
westway's Avatar
Thank you for the ebay link. However when I click on compatibility it says it wont fit a Vanden Plas. So what is the difference between a 4.2L XJ8 sedan and a 4.2L Vanden Plas relevent to theses seals? I also see the same seal for a 4.2L Range Rover. Is the range rover different also. All are 4.2L CONFUSED!
Old Nov 4, 2018 | 03:15 AM
Box's Avatar
Box
There are two 4.2L variants in the X350. Naturally aspirated and supercharged. If your vehicle is not supercharged, then those are the seals you want that go between the plastic intake runners and the aluminum rail for injectors. You will also need two metal sandwich style gaskets between the aluminum rail and the head.
Greykitty
XJ40 ( XJ81 )
Mar 24, 2015 11:46 AM
dfriedrich208
US Northwest
May 13, 2013 03:00 AM
dino
Sep 27, 2012 10:12 PM
1morecarplease
Apr 10, 2012 10:19 AM
Jon89
Feb 22, 2011 05:33 AM
