Shake at 70mph- Yes been through this before
Old Aug 3, 2023 | 05:39 PM
XxSlowpokexX's Avatar
Default Shake at 70mph- Yes been through this before
Well I get a shake at about 60-70mph that is now t real violent at "TIMES". This has been an ongoing on/off again issue for the past few years. I though perhaps it was related to my brake pad change a few years back as I was told sometimes that can cause this issue and seemed to occur after the brake change. It's not a warped rotor issue as there is nothing felt when braking, even hard braking. Occasionally the vibration seemed to go away then come back or change when hard turning at speed. Again a 60-70mph issue
More recently I did a tire swap. Had my wheels road force balanced and the vibration became violent. It does seem to change when again turning at speed or if I hit a bump....Which leads me to believe its maybe a suspension issue. I did a little bit of research and someone mentioned upper control arms going bad can cause this issue. The boots are torn but the car feels rock solid until that magical vibration point. I just want to sort out the issues I currently have with this car. I may just redo the entire front suspension but would like some thought on causation from some people that have had similar issues. Thoughts? And thanks in advance
Old Aug 4, 2023 | 10:56 AM
JoeDredd's Avatar
I have the exact same problem. Some time it does it some time not, but it is always at 65-70 mph, go over a little and it stops. On a private road of course, you wouldn't want to speed on the public highway
Old Aug 4, 2023 | 12:17 PM
Big Koshka's Avatar
Of course I don't! I just fly really low... this car, if to keep CATS, even lowers it's height at higher speeds to fit below radar!
Old Aug 4, 2023 | 12:33 PM
roviw's Avatar
I had a vibration on my 2004 Super v8, it was diagnosed by the dealer as being the " doughnut " propshaft joint, just had it changed and problem solved. I know there can be lots of things causing vibrations but in my case this was the issue. Worth a look for you maybe.
Old Aug 4, 2023 | 12:54 PM
JoeDredd's Avatar
What vibration did you have?
Old Aug 4, 2023 | 06:04 PM
Never thought to look, but I feel it in the steering wheel. Really seems suspension related
Old Aug 5, 2023 | 09:40 AM
roviw's Avatar
Ah, I did not feel mine through the steering wheel, mine was definately from the rear, nothing up to about 45 to 50mph but then got considerably worse up to 70mph, did not want to take it above that. As I mentioned when they checked it out they found a slight buckle on the rear wheels but then noticed the rubber joint was breaking down, they did the joint and I said to them I would sort out the wheels if needed as I have 3 spare Sepang alloys if needed.
After getting the car back I actually think there is virtually zero vibration at all now.
AngusJam
Dec 14, 2021 12:42 PM
martin49315
May 29, 2017 02:09 PM
F1wannaB
Mar 28, 2015 07:41 AM
artsjag
Nov 10, 2014 02:17 PM
emaraszek
Oct 14, 2013 12:03 PM
