shock failure on 2004 xjr
Old May 1, 2018 | 05:16 PM
paceconsul's Avatar
Default shock failure on 2004 xjr
No resistance to down travel at chuck holes Whats a cheap fix?
Old May 1, 2018 | 09:36 PM
Don B's Avatar
Hi paceconsul,
Welcome to the Jaguar Forums! It's great to have you with us.
I have moved your post from the forum for the X308 to the forum for the X350, which is the Jaguar factory project code for your 2004 XJR. Here you will find knowledgeable owners of similar cars.
There is a lot of existing information on the forum on the subject of the air suspension. A summary of the system can be found here:
Air Suspension & ECATS System Summary: Components & Operation
Without more details it's impossible to know if your problem is an uninflated air spring bladder or a failed shock absorber.
Does the suspension inflate properly and does it sit at the correct ride height at all four corners? Do one or more corners drop down overnight?
In the meantime, please visit the New Member Area - Intro a MUST and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers,
Don
pcmos
41
Dec 4, 2024 01:40 PM
dieselmedia
23
Mar 14, 2018 02:41 PM
abonano
Nov 2, 2017 07:49 PM
hisport
Apr 21, 2017 03:27 PM
nellerbeck
41
Mar 30, 2014 10:08 AM
