six stack cd player..
Old Aug 15, 2013 | 05:43 AM
Jaygee's Avatar
Default six stack cd player..
Hi.. All..
I have just upgraded my car to a 2003 XJ6 se 3.0 and find it has a 6 stack cd in the trunk also a single player in dash, the player in dash works great but after loading the trunk stacker it comes up NO DISK on the screen so i can only use the single player...
i would like to use the stacker but have no idea what is wrong......
any sugestions welcome..
regards
John...
Old Aug 15, 2013 | 11:13 AM
John,
I've moved your question from Jaguar Forums Advice / Feedback & Suggestion Center section to X350 section. The Advice / Feedback section is for posts about the forum and not for technical questions.
Members here with the same model as you have should be able to help with the CD player issue.
Old Aug 15, 2013 | 04:29 PM
Fraser Mitchell's Avatar
With these modern cars, the optional equipment usually has to be added to the electronic list of what the car has, so the new kit is recognised by the control unit in the dash. Alternatively, it has not been connected up correctly, so you may need to check in the boot to make sure, (having removed the LH side panel, of course.)
You may have to visit a main dealer to find out, but some specialists will also know how to find the problem.
Old Aug 16, 2013 | 02:01 PM
Jaygee's Avatar
Hi...
many thanks for the quick reply i have managed to get it going ..
it apears the previous owner had taken the fuse out , i put a 10amp fuse in and it is working great now..
Thanks and regards
John...
Old Aug 16, 2013 | 04:29 PM
Yeah, sometimes the answer is too obvious. You do have to wonder why "Charlie All-thumbs" needed to take the fuse out !
Old Aug 16, 2013 | 06:10 PM
34by151's Avatar
Yep makes you wonder.
Here is my theory
1. The previous owner blew a 10amp fuse
2. He was too tight to purchase a fuse
3. In a moment of brilliance he thought "my cd stacker does not work i'll use that fuse"
4. CD fuse removed and used elsewhere
With that level of thinking the original CD issue was probably all the CD's loaded in the caddy upside down
Glad its solved good luck with your new ride
34by151
Dimitrigregorio
17
Sep 5, 2019 03:47 AM
yarpos
Aug 31, 2015 07:04 PM
jimforrest (uk)
Aug 30, 2015 09:34 AM
Sentinelist
Feb 18, 2013 03:43 PM
andykhol23
Non-Jaguar Vehicles
May 28, 2008 09:31 PM
