Steering tie rods - when to replace?
Old Nov 4, 2013 | 01:49 PM
veffremov's Avatar
Question Steering tie rods - when to replace?
I was changing the brake pads and rotors on my VDP over the weekend and noticed the rubber booths on both steering tie rods were broken.
How do I know if the tie rods need replacement?
Old Nov 4, 2013 | 02:15 PM
Muddybear's Avatar
grab the tire at 9 and 3 with the wheels off the ground and try to wiggle the tire left and right. If the tie rods are loose you will feel a clunking from them. Helps to have someone wiggle the tire for you while you feel around on the tie rods.
Old Nov 4, 2013 | 05:36 PM
Fraser Mitchell's Avatar
If the joints are OK, you could always fit new rack boots. I cannot find one specific to the X350 on the internet (yet), but suspect the S-type ones will fit for the ZF rack, as so much of the X350 steering and suspension is similar to the S-type. I found some sites on ebay with the dimension, so useful for checking yours out. Main dealers may even supply them as splitting is not uncommon.
Old Nov 5, 2013 | 11:44 AM
Muddybear's Avatar
Also, if you can get under the car with the wheels on the ground you can have someone wiggle the steering wheel back and forth while you feel the tie rods for looseness.
Forcedair1
Sep 8, 2025 01:57 PM
PMKimpton
Aug 3, 2019 08:22 PM
sogood
Sep 15, 2015 07:35 AM
obwoodie
Sep 3, 2015 07:45 PM
KarimPA
Sep 3, 2015 07:32 PM
