Steering wheel automatic adjust
Old Nov 11, 2018 | 09:17 AM
kbeachy's Avatar
Default Steering wheel automatic adjust
My vehicle is equipped to raise and lower the steering wheel automatically when the key is inserted in the ignition. Recently I had to replace the multi-function switch on the left hand side of the column (the one that operates the headlights) because it was faulty. After the replacement, the automatic steering wheel raising function has stopped. Does anyone know the cause of that or how to reset it? I thought maybe that's a part of the programmable "dealer options," but it's not showing up through the SDD software. Thanks.
Old Nov 11, 2018 | 09:34 AM
Partick the Cat's Avatar
Make sure the switch is in the central (off) position; if it's left in one of the other positions (ie 'adjust distance' or 'adjust rake') the automatic raising function doesn't work.
Old Nov 11, 2018 | 11:57 AM
Sorry, I should have said the switch has to be central 'Off Position' between the 'Column Adjust' and the 'Pedal Adjust' positions. If it's left in either of those positions then the automatic repositioning of the column when your take the key out doesn't work.
Old Nov 11, 2018 | 06:06 PM
kbeachy's Avatar
That did the trick. Thanks.
baxtersuber
Sep 11, 2018 10:44 PM
frombenz2jag
Dec 12, 2013 10:58 AM
jacksonuga
Dec 1, 2011 11:22 PM
jaxhusky
Oct 12, 2010 03:08 PM
WinterJag
May 26, 2009 12:01 PM
