Test Mode Fails To Appear
Tried to put the 07 VDP into test mode, like the 04.
To my surprise nothing happened W T F
With door open, or closed, no luck.
Is there another way for the later model cars?
Trying to compare readings with proper working fuel senders.
Since both of the 04's fuel sender's replacement.
The reading is no longer going to empty when filled.
But is only reading 3/4, when the tank is full.
It does drop with the level, so thats much improved.
.With door open, or closed, no luck.
http://jagrepair.com/images/TSB/TSB2/NEW%20XJ/413Inst%20&%20panel%20illumination/Additional%20Diagnostics%20for%20Instrument%20Clus ter.pdf
X354 and X356 have completely different fuel tanks. don’t even waste your time
guestlinger
Aug 14, 2012 09:06 AM
