Tire size, 2004 XJ8, Interchangeability question
Old 10-11-2014, 08:50 AM
jphurlman's Avatar
Post Tire size, 2004 XJ8, Interchangeability question
Can I use a 225/55/ R17 on my car, I have a full set of Blizzacks I would like to put on this winter. The current tire on the car is the all season Pirelli 235/55/ R17?
Thanking you in advance for your help and advice.
Jim H
Old 10-19-2014, 01:06 PM
Dleit53's Avatar
I would sure think you will be OK with one size down. You might check the load capacity of the tires and verify you will not overload anything, but I really do not think you will even be close to overload, your car uses pretty large tires for the weight of the car.
jphurlman (10-22-2014)
Old 10-19-2014, 01:28 PM
GGG is offline
Received 16,820 Likes on 12,177 Posts
Originally Posted by jphurlman
Can I use a 225/55/ R17 on my car ........
Jim,
I've moved your question from General Tech Help to X350 forum. Members here with the same model will be able to help.
Old 10-19-2014, 04:03 PM
Fraser Mitchell's Avatar
Received 2,435 Likes on 1,941 Posts
There actually are 235/50 R17 Blizzacks available, what made you buy the narrower tyre ?
Having said that, I don't think it will make a huge amount of difference fitting a tyre that is 1 cm narrower than stock, after all these tyres are for winter driving at (usually) slower speeds. In fact I would think it makes no difference at all really !
Only thing I can think of is the tyre diameter may be different so your speedo may misread slightly. so check this out.
Old 10-20-2014, 04:51 AM
paydase's Avatar
The difference will be speedo reading.
Also in the EU, the difference in perimeter would be out of tolerance and you wouldn't pass MOT or Technical Control.
The right size for 17" is 235/55/17
Old 10-21-2014, 07:31 AM
jphurlman's Avatar
Wink Response to all
Thank you very much for your very helpful responses. I purchased the tires for a previous car. I will use them.
JimH
Old 10-21-2014, 08:08 AM
rosskuhns's Avatar
they generally recommend narrower winter tires anyway; better snow grip.
you can go to tirerack.com and they have lots of useful info on tire sizes that will fit, reviews etc.
Old 10-21-2014, 11:37 AM
jphurlman's Avatar
Smile Thank you
I went on the site and the calculator figured it was within spec to do so.
Thanks again for your help.
JimH
Old 10-21-2014, 03:24 PM
I gather last year you had quite a bit of snow in New York !!
Old 10-22-2014, 08:41 AM
jphurlman's Avatar
Yes we did and it was very cold, I hope I don't have any starting issues.
JimH
Old 10-22-2014, 01:00 PM
Normally starting issues when its very cold apply to diesels as the fuel waxes up.
jphurlman (10-24-2014)
Forcedair1
05-14-2023 03:28 PM
kelliott
05-31-2022 05:26 PM
RaceDiagnostics
09-07-2015 07:28 AM
Numwen
09-06-2015 12:30 AM
Sublyminal
09-03-2015 04:48 PM
Quick Reply: Tire size, 2004 XJ8, Interchangeability question
