Torque Convertor Drain Plug
Old Jan 23, 2013 | 09:04 AM
Jag XJ8 Red's Avatar
Banned
Default Torque Convertor Drain Plug
Does my 04 xj8 have one?
Old Jan 23, 2013 | 09:37 AM
Fraser Mitchell's Avatar
No, there is no means of draining the torque converter, which means getting new fluid throughout the tranny needs more fluid than just replacing that in the pan. A flush is needed and thus some new fluid will get contaminated by the old stuff. Of course, one can always just replace the fluid in the pan and ignore the stuff in the TC. Thats what a lot of people do, and it is normally satisfactory.
Old Jan 23, 2013 | 03:41 PM
Banned
I wonder if anyone has tried the DIY flush. Disconnect the cooler lines. Put the out in an empty bucket and the in into a container of ATF. I have done it on other cars. Worked fine as long as you don't let the in bucket run dry.
Old Jan 24, 2013 | 01:00 PM
Banned
I guess not. It is easy to do and flushes out all the old fluid. You only waste a liter or two.
Don't even have to drop the pan although that is best.
Old Jun 3, 2024 | 12:58 PM
JAGUAR.AD33's Avatar
Seems to me that this is the only way to do it ,i mean whats the point doing it via fill hole 3 litres in max ,esp if youve had a leek and unsure whats in there to start with??anyway im going try it .I MAY BE SOMETIME LOL.
Old Jun 3, 2024 | 07:33 PM
Six Rotors's Avatar
If you look in the first Sticky above, go down the list to Transmission you will find years of experience recorded there.
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
Scarecrow
Mar 28, 2016 03:17 AM
Jose
Mar 22, 2016 04:59 AM
chatmanx
Sep 11, 2015 07:17 PM
