Traction
Old Sep 13, 2010 | 02:55 PM
Drew's Avatar
Default Traction
I was wondering if anyone has put wider tires on the rear of these cars. I have read almost all the article from the XF, XK and XJ. They all pretty much have the same engine, trans and weight. The only major difference is the tire size on the Xk is wider. The XJR is about .5 second slower than the XKR. Is it possible to get a 285/35/19 on a 19x8.5 rim? I think the 0-60 could drop a .5 second and keep with the XKR. The only factor I can think of that would keep the XKR faster is shorter wheel base that transfers weight better and if the rear end has a larger gear or LSD. I know my 04 with 255/40/19 can spin the wheels at 30 MPH.
Old Sep 14, 2010 | 05:33 AM
JagMaster's Avatar
If you put wider wheels on back, sure traction will be better but 0-60 times will be slower, the XKR weights 3,690 lbs where XJR weights 3,946 lb and ofcourse XKR has a shorter and lighter drive shaft, the LSD and gears remain same though.
Old Sep 14, 2010 | 09:25 AM
Drew's Avatar
The 0-60 would be slower than the stock XJR or still slower than the XKR?
Old Sep 15, 2010 | 02:52 AM
JagMaster's Avatar
It will be slower than the stock XJR
How do i know this?
I actually tried this on my S500 back in time , i had better grip on high speed corners tho so it was worth it
Old Sep 15, 2010 | 06:44 PM
carmat731's Avatar
I've read several articles that suggest wider (therefore larger) tires increase unsprung weight and can reduce acceleration. However one would think that a wider tire would have better traction at launch.
Old Sep 16, 2010 | 10:24 AM
Drew's Avatar
I agree with the additional unsprung weight, If you don't have enought power to offset it. My 04 XJR has power to spair and I have spun the tires at 30. If your car couldn't spin the tires off the line and you put a wider tire on...it would definately slow the car down because of weight.
kingdom worker
Nov 14, 2020 03:47 PM
Johnken
Apr 8, 2018 10:21 AM
JagBrian
Oct 1, 2015 12:52 AM
mrplow58
Sep 30, 2015 08:56 AM
