Transmission fault light
Got an amber transmission fault light today, car has been driving fine and it went away after I restarted it, could this be a random blip or is time to offload it before things expensive?
66400 miles, 04 XJR
Thanks, Damian
66400 miles, 04 XJR
Thanks, Damian
I think you referred to limp mode. It may be as simple as a sensor glitch or could be heads up for an upcoming failure . Mine did light up yesterday as well. It was hardly moving but once you get up to speed you feel no drama at all .
I drove home and killed the engine , started it off no lights same as yours
I'd had one rough change a month or so back but nothing recently - is a transmission reflash something the dealer would have to do or could an independent do it?
I think I preferred the old days where the only lights were oil pressure and the your engine has just exploded light
KarimPA
Sep 12, 2015 08:15 AM
OkieTim
Sep 8, 2015 04:48 PM
KarimPA
Sep 3, 2015 07:32 PM
