trouble programming key fob
Old Sep 18, 2010 | 08:42 PM
Rae's Avatar
Rae
crbea232: First and foremost, ensure all numbers on back of fob match original fob. Second, do a search for programing (no offense intended), there are plenty of reply's. I won't try to replicate exact instructions, just struggled through this myself. Most are the same. Start off with new batteries, have all key fobs available, you must do all at same time. Ensure door is open & high beam switch is pulled back before inserting key and the turning key to #1 position, then flash high beams 4 times, then press unlock or lock button on fobs a total of 5 times (not 5 each, 2 & 3 times each for a total of 5). If you don't succeed, try again, it will work eventually. Good luck.
Ralph
Old Sep 21, 2010 | 07:34 AM
squish's Avatar
Originally Posted by crbea232
I have a 2005 XJ8. Any other ideas?
Have you asked in the forum dedicated to your model?
Old Sep 21, 2010 | 02:50 PM
Cadillac's Avatar
Moved off to the correct area
peterg19
Feb 10, 2023 09:02 PM
perezal
Dec 29, 2015 08:48 PM
SeanU
Sep 18, 2015 03:38 AM
jfitzoz
Sep 7, 2015 04:28 AM
My Pham
Sep 4, 2015 03:37 PM
