Trunk Lid not poping up
Old Jun 10, 2019 | 07:32 AM
blj54's Avatar
Smile Trunk Lid not poping up
( Just an FYI ) I have had my car sense Feb and the trunk would not pop up unless you were standing right there pulling up with slight pressure when release button was pushed. I discovered yesterday the square part covering the latch in the trunk unsnapped and I found that the spring loaded (push up pin) had very limited up and down movement. I rotated plastic pin and found it has a locking slot, when I aligned with slot pin extended out almost a full inch. Now when I open trunk it works as it should :
Old Jun 10, 2019 | 09:45 AM
Wingrider's Avatar
Getting to know ones vehicles on an up close & personal level, is necessary to avoid the unneeded expense of a visit to a mechanic.
Old Jun 12, 2019 | 09:32 PM
Carlyle Holder's Avatar
i have a2004 XJR and the gas and trunk are not opening from the dashboard. Any suggestions?
Old Jun 13, 2019 | 09:39 AM
JoeDredd's Avatar
Does the trunk ( boot over here) make the motor noise when you close it or do you have to slam it shut? If you have to slam it then the lock asm probably needs replacing. I managed to bust mine by over filling the boot and the motor in the latch made a really nasty noise and that was that done for. Good job there is ebay lol.
My fuel flap is a bit flakey and I have to wedge a credit card in it then press the button and it will open. If I dont I can see the flap move but it wont open fully, I think it needs a good clean.
Old Jun 18, 2019 | 03:54 PM
mikebaker3's Avatar
What I learned was that driver door has to be open and engine off before the gas door switch will work.
Roger Mabry
Sep 26, 2018 11:12 AM
neil0131
Jul 26, 2017 06:59 AM
S Daddy
Oct 9, 2016 10:26 AM
Salu498
Jul 20, 2016 07:35 PM
