Upper control arm bolt troubles.
Old Jan 27, 2025 | 04:12 PM
PeteK812's Avatar
Default Upper control arm bolt troubles. Solved!
I just started the installation of a complete Arnott coil conversion set, and have hit my first snag. The heads on the upper control arms are kind of narrow, or shallow, and a 17 mm tool has a loose/sloppy fit. They seem to have a high torque value, but I see rounded corners in my future before I get them broken loose. Any tips? I'm replacing them on the advice off Don B, so if it all goes awry, at least I'll know who to Blame. Whom.
Last edited by PeteK812; Jan 27, 2025 at 09:51 PM. Reason: I want to add the word: solved
Old Jan 27, 2025 | 09:49 PM
PeteK812's Avatar
I thought the bolts went into captive nuts like at the bottom of the shock absorber. When I discovered the meaty locknuts on the other end of each bolt that was the key. Getting to them with a box end wrench, now that was the start of a new brain teaser.
Pedro soto
Jan 31, 2022 07:21 AM
exiledbrit
Apr 16, 2021 11:52 AM
prodigy215
Jun 10, 2020 02:31 PM
NEO Cat
Nov 6, 2016 05:58 AM
Noxparadise
Nov 24, 2012 02:49 PM
