Valley Coolant Hose and parts
Old Dec 16, 2014 | 09:46 PM
dsetter's Avatar
Default Valley Coolant Hose and parts
Well, my 10 YO cat has become a little incontinent and dropped its cooling fluid.
It seems to be be dripping from the back and an inspection seems to suggest that it is the hose under the supercharger.
I have recently had a puffy radiator hose and the expansion tank replaced.
I plan on pulling the SC etc off and seen many links on this but no list of parts.
As I understand it from some of the links, the parts required are:
  • Heater Feed Hose
  • Return Hose
  • EGR gasket?
  • TB gasket
  • TB Elbow gasket
  • SC outlet duct gasket
Appreciate any help as I am not easily able to find the items I think I need on the parts diagrams.
Old Dec 17, 2014 | 02:00 AM
JagV8's Avatar
Some of the hoses & gaskets such as the valley pipe will be as per the STR. Some posts give parts in the S-Type forum e.g. by Bull27 and tbird6
Proper name may be Throttle Body Coolant Return Hose
for google/etc searches.
Old Dec 17, 2014 | 10:53 AM
dsetter's Avatar
Default Valley Hose parts list
Have compiled the following to try and have another complete thread.
PART# QTY Description
AJ89746 1 Heater TB Hose ---> Leaks New version
AJ88507 1 Heater TB Hose
These are the two hoses that tend to leak.
Peripheral seals and gaskets. Some 'could' be reused.
AJ86892 2 Blower to IC duct seal
NCC7735BA 1 SEAL SC OUTLET
AJ83292 1 Induction to SC Gasket
C2C11477 1 Thermostat tower Oring seal
C2C17430 1 Throttle Body Gasket
AJ88559 2 EGR Valve gasket
AJ88560 1 EGR Valve gasket
AJ811758 1 Coolant EGR hose
AJ88514 1 Coolant EGR hose
Will try and photograph and document for reference.
dsnyder586
Dec 29, 2024 07:39 PM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
