vibration
Old Aug 14, 2018 | 10:38 AM
alatoni14's Avatar
Default vibration
my 2004 xjr has a vibration around 2000 rpm the faster i go the less it felt i had 1 bent rim repaired at 1 motor mount also done but i still have the issue
what could it be driveshaft etc etc
alberto
Old Aug 14, 2018 | 03:53 PM
Dan R's Avatar
Get the wheels balanced? It worked for me.
Old Aug 18, 2018 | 10:53 AM
alatoni14's Avatar
Default Xjr vibration
Gentlemen
I should have explained my self better I have a vibration around 1800 rpm with the car either in park neutral or driving what can cause something like that
supercharger is in the process of being swap knowing my rotors are chattering making loud noises could that cause vabration.
thank you
Old Nov 1, 2020 | 06:00 AM
Hendirk's Avatar
Hi Alberto,
did you find the source of your vibrations? I have a 2004 XJR too and since I own the car the engine vibrates at 1.800 rpm. TH whole car shakes an I can feel it in the seat + steering wheel + dash. The vibrations appear when the transmission is in D/R but also in P/N when standing still and revving up to 1.800 rpm. I thought it might be the engine and transmission mounts but nope - changing them did not make any difference :/
Thanks!
Old Nov 1, 2020 | 06:07 AM
JaguarXKR's Avatar
Sounds like motor mounts to me.
Old Nov 1, 2020 | 06:10 AM
Hendirk's Avatar
Thanks for the input! That was my first guess too, so I replaced them (both engine mounts and also the transmission mount). The engine now runs way smoother but the strange vibration at about 1.800 rpm is still there ...
XKRoger
Apr 26, 2024 05:50 AM
Jnelso
Jul 26, 2020 10:56 AM
HotWheels63
Jan 30, 2020 12:35 PM
scott
Jan 4, 2011 12:07 PM
