Voice Activation
Old Apr 21, 2014 | 12:47 PM
josemald's Avatar
Default Voice Activation
I own a 08XJ8L it doesn't have VA but I think Jag sells an upgrade unit part #7W9310D893AB. does anyone have any knowledge about this part? is it plug and play? Help Please!!!!
Old Apr 21, 2014 | 01:00 PM
trosty's Avatar
No, Sorry, No idea.
But you could start here: https://www.jaguarforums.com/forum/x...re-wire-48216/
Old Apr 21, 2014 | 05:34 PM
Cambo's Avatar
Not sure about that part number of the top of my head, but a voice module is basically plug & play, if you have the right one, and you extend the fiber optic network to accommodate the extra module. Lots of threads here on the forum about the network.
I fixed the thread title for you, welcome to the forum.
Old Apr 22, 2014 | 01:14 PM
veffremov's Avatar
The module you mentioned looks like a phone module (aka PSE). I'm not 100% sure, maybe they decided to combine the voice and PSE in one unit.
Depends on your definition of Plug and Play - there is a plug for it in the trunk. As cambo mentioned you will need to extend the D2B optical network with one mode node (plug), which is not hard, but you'll need the cable parts for it. The D2B network is a ring of optical cables that go from one device to another. It is important that the ring is complete.
You may be lucky and there may be an unused D2B port in the trunk - it has a mini loop plug that passes the signal.
So it's not a 2 day job, but not 10 minute either. Other than that the car would recognize the unit automatically if you have navigation unit. If you have normal radio, it may require some reconfiguration from the dealer.
Old Apr 23, 2014 | 02:37 AM
JagV8's Avatar
Worth putting it into google. Even better if you know to drop the AB when looking out of curiosity.
Jul 9, 2018 01:44 AM
jdzubas
Oct 4, 2015 09:14 AM
sdelliott58
Sep 28, 2015 11:21 PM
AnD3rew
Sep 26, 2015 06:06 PM
