Voice Activation Pre-Wire
Old Jan 9, 2011 | 12:59 PM
Chuck08XJR's Avatar
Default Voice Activation Pre-Wire
I was going through my Vehicle Details and it states Voice Activaion Pre-Wire. My car dosent have voice on it (or atleast I couldnt figure it out). What does this mean? Can I get the voice option installed? If so what does it take?
Old Jan 9, 2011 | 07:02 PM
veffremov's Avatar
If you have a phone - it takes a voice control module (installed in the trunk) and a new D2B cable harness.
If you don't have a phone, you will also need a mic installed in the overhead console.
Old Jan 9, 2011 | 07:14 PM
veffremov's Avatar
The voice module is quite rare in US, but there is a bunch of them in UK ebay
http://cgi.ebay.co.uk/Jaguar-X-Type-...item4cf446ea29
Old Jan 10, 2011 | 08:14 AM
Chuck08XJR's Avatar
Thanks for the info. I dont have a factory phone installed but my bluetooth works and there is a mic installed next to my visor. Is this "voice module" you speak of the same for all models?
Old Jan 10, 2011 | 06:09 PM
veffremov's Avatar
I got a module from an S-Type and it works just fine.
Old Jan 11, 2011 | 08:00 AM
Chuck08XJR's Avatar
Thanks veffremov now the journey begins for finding one.
Old Jan 12, 2011 | 01:09 AM
u102768's Avatar
How easy was it to get the D2B cable and can you remember what it cost?
Does the car need to be reconfigured to recognise the new feature?
I assume you lose the use of the mute function on the left hand steering wheel button?
Old Jan 12, 2011 | 05:31 PM
veffremov's Avatar
The dealer will give you a whole new D2B harness for about $120-$170. If you score a spare D2B connector from eBay, you can add it to the loop yourself - they are easy to assemble/disassemble.
In theory you need to go to the dealer to reconfigure the car, mine worked fine after I added PSE and voice so I did not.
The "mute" function becomes the "listen" function on the voice system. I don't know what it does if you press it while talking on the phone.
Old Jan 12, 2011 | 05:33 PM
veffremov's Avatar
Btw. on my car there was a spare D2B connector in the trunk which has a "loop" passtrough thing attached - I think it's close to the amp. You can use that connector too.
Old Jan 12, 2011 | 08:53 PM
Chuck08XJR's Avatar
I'm not real sure I have seen that cable but I will dig into it deeper. I guess I will call my service manager and see what that will cost. Thanks
Old Jan 13, 2011 | 02:15 AM
u102768's Avatar
If you haven't seen them before the fitting instructions are attached.
File Type: pdf
Old Jan 13, 2011 | 09:46 PM
Chuck08XJR's Avatar
Great information. Thanks
Old Feb 24, 2011 | 07:51 AM
sleepyastronaut's Avatar
Sorry to hijack your thread, but if anyone could help me with a D2B aux-in, I would very much appreciate it: https://www.jaguarforums.com/forum/s...ad.php?t=50299
Old Feb 24, 2011 | 02:12 PM
xjrguy's Avatar
Here is what you need to install voice activation in your XJ. The part numbers listed supersede to new numbers, but they will get you where need to go. It really isn't too big a job. Your 2008 probably already has a mic for the bluetooth, so that part is already done!
Cheers,
File Type: pdf
Old Sep 22, 2011 | 07:08 AM
dd823's Avatar
How about one for a 2008 XKR
Old Sep 22, 2011 | 08:23 AM
kthrash's Avatar
If you have navigation you can turn on those options without going to the dealer.
Old Sep 23, 2011 | 08:19 AM
Chuck08XJR's Avatar
Please tell me more. I have kinda put it on back burner but I am ready to perhaps open this can of worms.
Old Sep 23, 2011 | 02:55 PM
kthrash's Avatar
hold the phone/menu buttons in, type in 1971, select options I think and you can turn on/off options after you install the hardware.
Old Sep 23, 2011 | 04:11 PM
Chuck08XJR's Avatar
Thanks. Now I just need to track down the hardware
Jul 9, 2018 01:44 AM
jdzubas
Oct 4, 2015 09:14 AM
sdelliott58
Sep 28, 2015 11:21 PM
AnD3rew
Sep 26, 2015 06:06 PM
