Weak A/C anecdote
Old Aug 6, 2022 | 05:54 PM
Eric's XJR's Avatar
Default Weak A/C anecdote
FYI how I solved my air conditioning problem. I found a leak, replaced the part and charged it but was still experiencing inadequate cooling. I noticed the the A/C worked better at speed so I started looking at air flow.
The fan would run, had battery voltage, ignition voltage, ground and variable voltage on the signal wire but was not running enough for the A/C. Instead of doing further testing I decided to just replace the fan.
I installed an aftermarket fan that advertises 3000 cfm and a variable speed controller. The difference in the air conditioning is huge. The A/C doesn't just run a little colder, it blasts cold air.
Old Aug 10, 2022 | 01:56 PM
mhamilton's Avatar
Thanks for the tip--I suspect my own fan is lacking at idle as well as ac is much better once moving forward with ram air. Was this a direct fit replacement fan?
Old Aug 10, 2022 | 04:46 PM
Eric's XJR's Avatar
Default universal fan
I removed the original fan motor from the shroud and replaced it with a universal fan. I wanted to reuse the shroud in order to get the right fit and have the original mount for the auxiliary coolant pump.
klynn
Jul 31, 2025 04:56 PM
IsmoL
May 14, 2021 06:56 PM
Razor
Jan 6, 2016 11:26 AM
tootles
Oct 10, 2012 06:06 AM
Jagm1979
Jul 30, 2012 04:51 PM
