What does the second pair of headlight adjusters do? Pics provided.
Old Aug 26, 2018 | 08:58 PM
Blairware's Avatar
Default What does the second pair of headlight adjusters do? Pics provided.
I have read a fair amount of, if not conflicting, you could say differing info on our Headlights and methods to adjust them. Here is my issue, and I am hoping to get some clarity on this.
There are some eary cars that use the air suspension to level the car, and thus the headlights. They do so in a smart way, always leveling the rear of the car first, and then the front in an attempt to mitigate blinding oncoming drivers. My car, a 2007 Vanden Plas doesn't have any of this, nor does it appear to have any automated or motorized headlamp aiming mechanism. What it does have is a 6mm hex fitting that allows vertical adjustment of the low beam HID (previously called "Xenon") headlights. They work well, are bright, white and focused decently through a projector lens.
The low beam adjust is in the middle of the housing - The presumably High Beam adjust is over the high beam lenses- except it doesn't appear to do anything - is this a horizontal adjust, and mine are broken (both of them?) - I have spent a lot of time running the adjuster from one extreme to another - with virtually no notable effect. I will post a few pics of these when I get home from work today Low beams are perfect as far as aim. High beams seemed ok, but they do leak some light pointing almost straight up. Any thoughts, experiences, instructions etc. would be SO appreciated!!!
Old Aug 27, 2018 | 05:57 PM
meirion1's Avatar
I have successfully adjusted my lights manually quite a while ago so don't remember the details.
I reckon you have four manual adjusters (two per side) at least one of which is not working.
There was another post here (a couple of days ago) complaining about adjusters not working.
The whole bl**dy lot is plastic like a child's toy and I think you are looking at removing bumper,
removing light unit from vehicle,dismantling light unit, if that is possible and then repairing the
adjuster if that is possible!
Old Aug 29, 2018 | 05:01 AM
-Greg-'s Avatar
I tried same and only one adjuster works on both lenses. Other one does not seem to do anything (although I did turn it both directions for about an hour )
Old Aug 29, 2018 | 08:45 AM
Partick the Cat's Avatar
I had the same experience; the outer adjusters moved the dip beams up and down, the inner adjusters seemed to move nothing.
Old Aug 30, 2018 | 07:12 PM
Dr John's Avatar
On my 2008 the inner adjuster moves both beams side to side and the outer ones move both lights up and down. I was looking for a way to adjust the high and low beams separately but they move in unison.
DGorvetzian
Mark V - X 420G
Aug 26, 2018 08:55 PM
