white smoking like crazy!
Old Jun 29, 2023 | 10:33 PM
josh_77073's Avatar
Default white smoking like crazy!
a couple of weeks ago i accidentally got caught up in race. im already a fast driver but i do not drive my car hard being that it has 200k miles but i never had any struggles with power. while driving on the freeway i saw two cars racing, so i hit the peddle to see the outcome. after going at high speeds the other car figured i wanted to race too so i said why not. shortly into the race the other car took the exit off the freeway. with the next few miles my car went into “restricted performance”. i then noticed my car was making white smoke. after returning home i pulled in the garage the next day i went for a quick spin, my restricted performance reading went out but my white smoke has not stopped and i have a small rough idle. i know its not a blown head gasket, my coolant hasn’t went down and my oil isn’t milk. i was thinking i have some clogged injectors. i hooked my ob reader up but no codes are given it reads “follow repair solutions instructions at PC to transfer data” i dont know what that means. so i come to the experts. help me guys! attached is a video i revved to 2500 rpm.
File Type: mov
Old Jun 30, 2023 | 01:35 AM
FreeWifi's Avatar
Does it smell sweet or like gas at exhaust? Could be stuck injectors and fuel wash if you are smelling gas. Should have codes stored. Wouldn't drive it until you know for sure and get it fixed. If it smells sweet it's likely a head gasket even if you haven't noticed a lot of coolant loss or milkshake yet. Could just be a small leak for now. Worse case, a cracked blocked or cylinder but doubt that. Have you taken off the radiator overflow cap and look for air bubbles while someone revs the engine? Or you can get a head gasket test kit. But if you have a strong gas smell then I would agree with stuck injectors.
Old Jun 30, 2023 | 06:06 AM
EsRay's Avatar
This may be a total misnomer, but years ago I had ridiculous white smoke out the back of my 2005 XJ8L...Turned out to be a crack in a transmission clutch drum, that 'locked up' when it heated and expanded?
Here's hoping this is not your problem, 'cos it means Trans out?
Old Jun 30, 2023 | 05:46 PM
josh_77073's Avatar
no sweet smell, no milky oil, coolant is fine. no air bubbles either. i also been watching my oil consumption thinking it can be bad rings. i have never changed my fuel injectors either so that’s what made me think it would bad injectors.
Old Jun 30, 2023 | 05:48 PM
josh_77073's Avatar
no never locked up at all. burning tranny fluid has a very distinct smell so i would know if some kind of tranny issue would be the culprit.
Old Jun 30, 2023 | 07:06 PM
xalty's Avatar
pcv diaphragm. when they go bad it makes clouds of white smoke
with stock cats it comes out white not blue
Old Jul 3, 2023 | 06:28 AM
redrover41's Avatar
Like xalty said the white smoke points toward the pcv. But also check the air tube from the air cleaner box to the throttle intake. If that tube is loose at the intake it will throw white smoke out the exhaust pipes at a huge rate.
Old Jul 3, 2023 | 08:31 AM
luv2fly's Avatar
Not sure about the white smoke, but restricted performance and misfire could be plugged cats. Had that happen to me after a speed run, also on a Texas road. Should see codes for random misfire.
Old Jul 3, 2023 | 08:50 PM
josh_77073's Avatar
i ordered a pcv valve and new cats hope this will fix my issue if it doesn’t im sure its going to cost me a lot more money.
J.A.G.
Jan 9, 2022 09:56 PM
EnRoute30
Mar 3, 2018 08:58 AM
Quartzboy
Jul 20, 2015 10:32 PM
GreenHorn
Jun 14, 2014 08:35 AM
cpm53
May 1, 2011 06:09 AM
