Will not start - immobiliser
Old 07-14-2013, 03:06 AM
charlie786's Avatar
Default Will not start - immobiliser
Hello, hope somebody on the forum can help before I have to take car to Taggarts.
I have a very nice Jaguar XJ6 3.0 V6 auto 2003.
I had to have the ecu replaced as it got water damaged.
Got a ecu with the same serial and had it programmed. now car will not start, nothing at all starter will not turn so I am guessing its the immobiliser.
I have searched the internet and tried the trick where you reset the immobiliser by touching the earth and positive battery leads also tried the trick where you leave the battery negative terminal off for 30 minutes. I have checked the voltage on battery shows 12.08v doors open and lock via remote. Many thanks in advance
Old 07-14-2013, 09:27 AM
paydase's Avatar
Default Battery tension
Hi,
Not sure it comes from the battery but from what I know, these cars are very sensitive to the battery tension and 12.08 is way too low!
Old 07-14-2013, 06:23 PM
meirion1's Avatar
Has the car been starting and running since replacing ECU?
If you suspect battery have it tested under load ie monitor voltage drop under
load.
Old 07-16-2013, 11:57 AM
charlie786's Avatar
Yes ECU had been changed all the serial numbers are the same.
JarodL
03-07-2024 01:39 AM
Dagny
07-20-2020 05:39 AM
99xk8guy
09-21-2019 07:34 PM
Bones
09-08-2015 08:34 PM
Doovoe
XJ40 ( XJ81 )
09-06-2015 10:54 AM
Quick Reply: Will not start - immobiliser
