Window Switches
Old May 27, 2014 | 04:23 PM
oldmots's Avatar
Default Window Switches
My drivers window switch for the front passenger window will only lower the window whether it is pushed up or down. The passenger window switch will raise and lower it! I replaced the drivers switch pack and it still does it. This behavior stopped for awhile then resumed the problem with no particular causal event.
Old Jun 3, 2014 | 11:40 AM
mark campbell's Avatar
sorry i don't have an answer but i had the same problem---with rear pass. door ---i had spare parts ---main and regular window switches --drivers door modual ---body modual ==is located next to battery----ever wire diagram from here ==that did'nt match some of the wires on the car ------i swiched out all of above to no avail ------then sold car -new owner was ok with it----------i wven asked this ? here --but now responce ----hate to be a downer --but i hope you get it fixed
Old Aug 1, 2014 | 11:42 AM
rcwkr's Avatar
My problem popped up a couple weeks ago. My front passenger (rt) window will not operate with either switch, and the pass. switch operates the rear one same side. The global lock/unlock thingy will lower all windows 1/3, but it was dicey bringing the ft pass up!
Old Aug 9, 2014 | 01:42 AM
04XJwpg's Avatar
My car likes to one touch down when I tell it to one touch up sometimes. A little annoying in the rain or cold but I can live with it for the most part.
Old Aug 9, 2014 | 12:17 PM
rcwkr's Avatar
As it happens, I'd needed to replace my 6 year old dealer installed battery, which I'd been putting off for a year or so.
($121.00 on sale @ Advance Auto, BTW)
Guys, don't be a cheap ******* like I was. If you need a new battery, GET ONE!
It cures all sorts of gremlins, including my window issue. Might've just been the disconnecting and reconnecting, but I'm sure that other issues I'd had were low voltage related. I now have a nearly glitch free 17 year old luxury muscle car!
rentzoo
Nov 10, 2015 04:56 PM
LnrB
Sep 18, 2015 09:48 AM
RaceDiagnostics
Sep 13, 2015 02:22 AM
jagent
Sep 12, 2015 09:10 AM
1964Daimler
Sep 9, 2015 11:28 AM
