Wiper problems
Old Mar 21, 2019 | 02:36 AM
Quailemp's Avatar
Default Wiper problems
Hi guys wipers on my xj6 wont turn off even when ignition off any suggestions will be most welcome
______________
2007 XJ6 Sovereign diesel (added by GGG)
Old Mar 21, 2019 | 08:09 AM
Welcome to the forum Quailemp,
I've moved your question from X351 (2009 onwards) to X350 (2003 - 2009) forum. This is the place to post questions about your 2007 XJ6.
Old Mar 21, 2019 | 08:22 AM
mhamilton's Avatar
Wipers are controlled via 2 relays (R4 for on/off and R8 for hi/low speed) in the underhood fuse box and the FEM. If the FEM isn't receiving the park signal from the motor, it won't know when to stop. Or you have relay R4 that is stuck on. Pulling R4 will stop the motor. You can swap it with R8 to verify it's not the issue. If the motor still runs, then it's going to be time for a new motor as the park switch is bad internally. The only confirmation of that will be through SDD to read the state of the wiper park input. Could also be a bad ground at the wiper motor-to-body, but that is lower on the list of possibilities for "stuck on."
I would not suspect the wiper stalk since if that was stuck on, the wipers would still be shut off by the FEM when you turned the ignition off.
milleniumaire
Oct 1, 2020 05:59 PM
Stuckonbrits
XJ40 ( XJ81 )
Aug 24, 2014 11:38 PM
Gregfromuk
Oct 7, 2013 03:03 PM
StayFrosty
Oct 6, 2009 06:24 PM
