Won't start
Old Jan 30, 2022 | 01:01 PM
mghirsch's Avatar
Can you scope the CPS? I know it is new, but new means (according to the Car Doctor) Never Ever Worked.
Old Jan 30, 2022 | 02:33 PM
killroy's Avatar
sound like you learned yourself a new lesson. test light lighting has nothing to do with amperage and you need amps to turn a starter not voltage glad to hear you figured it out.
Old Mar 18, 2022 | 05:43 PM
rcannon's Avatar
Thanks for the info. My 2004 has been sitting all winter and won't start either. Now I have some things to check. Also FYI there is also a fuel pump switch that trips sometimes that you can reset through a hole by the hood release.
Old Mar 18, 2022 | 06:13 PM
Parker 7's Avatar
I just had the alternator bearing go out and took it to a alternator shop to have the bearing replaced
Your other electrical systems being effected points to one of the main power distribution relays on the car for a section
There may be a specific relay for the fuel injectors like on the earlier X308 V8
The relay can be intermittent and be swapped with one of the same part #
Researching
Old Mar 18, 2022 | 07:15 PM
Parker 7's Avatar
No , there is no specific fuel injector relay for the V6 or V8 2004
Do you have starter rotation ?
The inertia switch does not always reset and you can jumper across the connector
HeavyMetal80
Sep 24, 2024 12:30 PM
ra.stewart
Feb 25, 2019 09:18 PM
KenAdamson
51
May 28, 2017 12:01 AM
Neil MG
Dec 4, 2012 10:05 AM
HouseCallAuto
XJ40 ( XJ81 )
Jun 27, 2011 11:07 AM
