X350 touch screen digital clock
Old Oct 25, 2019 | 08:27 AM
Clapton7's Avatar
Default X350 touch screen digital clock
Hello all,
We all know and respect the analog clock located in our Jag's dashboard.
I recently saw someone has a digital clock on his car's upper right touch screen, (as shown).
(It's a good idea synchronized it to other area on planet Earth
Is it an inherent part/feature in our cars model?
Old Oct 25, 2019 | 08:38 AM
Partick the Cat's Avatar
On 350/8s that's only a feature on later cars and then only on ones fitted with the additional digital radio option, ie DAB, [or presumably (in the US) satellite radio].
Old Oct 25, 2019 | 09:58 AM
Sean W's Avatar
Here's some info on a retrofit if you're interested. It's a great write up.
https://www.jaguarforums.com/forum/x...l-x350-171967/
Old Oct 25, 2019 | 11:30 AM
Clapton7's Avatar
Originally Posted by Partick the Cat
On 350/8s that's only a feature on later cars and then only on ones fitted with the additional digital radio option, ie DAB...
OK,
Tough luck as my vehicle's VIN is few thousands BELOW "Jaguar" mentioned range...
Although, I still like my cat even under this HARD situation. ;-)))
File Type: mpg
Old Oct 25, 2019 | 12:13 PM
Even if it were in-range the bits really aren't cheap.
The tuner is over £500 new but can be had for about £80-120 secondhand. However, the killer is the 'gateway', which is an interface between the tuner and the rest of the hifi system; that's also over £500 new and secondhand, quite apart from cost (which will be high if the vendor realises what it is) ... they are very very rare.
Old Aug 23, 2023 | 08:30 AM
mcpflrb's Avatar
The digital clock I think is there if the navigation setup is for the S Type X202 or X Type X400 instead of the X350 - keeping in mind the former do not have an analog clock. I think you can change the navigation in the XJ to setup for the S or X Types and get the digital clock but have not yet tried and don't know what other differences there will be. Mercedes in the W221 has an analog clock but also a digital clock in the nav screen - it sort of feels like it's missing in the X350.
drdude21
Aug 2, 2018 10:50 AM
Seth
Aug 13, 2012 09:19 AM
loulizjag
Mar 16, 2012 06:06 PM
danjkxfsc
Aug 14, 2011 07:24 PM
