X350 XJR Suspension Swap Question
Old Feb 17, 2025 | 09:56 AM
EsRay's Avatar
Originally Posted by FastEddie02043
Greetings,which ohm resistor did you use , i put in a 1k ohm resistor in each connection but still have a fault ? Thank you, Ed
I used: Metal-Film-Resistor-1W-1-1K-ohm-1Kohm
Perhaps clear the message if you have a Jag specific reader? If not, hard reset?
Just to check, this resistor is to clear a CATS System error message, not a Suspension Fault?
Old Feb 18, 2025 | 10:16 AM
viper1996's Avatar
Originally Posted by EsRay
For some reason, my 2005 XJ8L still needed the CATS fault message dealing with after fitting coilovers. The solution was:
20PCS 1W Metal Film Resistor 1% 1R~1M 15 100 220 470 ohm 15R 100R 220R 470R 1K 100K 510KΩ - AliExpress 502
I just pushed each end of the resister wire into the two females on the ends of the CATS plugs at the airsprings, then shrink-wrapped them?
CATS message, gone.
Might help you if you find the same problem?
Man that's great information...!!!
Old Feb 18, 2025 | 11:28 AM
EsRay's Avatar
Thanks, but the credit must go to Member WWR
https://www.jaguarforums.com/forum/x...3/#post2195138
Old Feb 18, 2025 | 12:02 PM
Jimford88's Avatar
Originally Posted by Wooford XJR
I replaced my Cats Suspension on my 05 XJR with a set of used struts from an S-Type. I unplugged the ASN Module from behind the back seat. Lights are out and no regrets. The car sit about 1/2 inch lower than stock which I like.
hi there, height looks good. Iam also thinking of using the s type struts for mine, how was the fitting? Is there any modification to the vehicle for these struts to fit? Or is it a straight swap ? Thanks
Dassaul
Jan 19, 2025 07:49 PM
Oberkellner_XJ8
Sep 13, 2023 10:36 AM
hisport
Apr 11, 2022 04:59 PM
kbeachy
Aug 18, 2019 10:50 AM
rhs
Feb 6, 2018 08:01 PM
