X358 starting issues (possible fueling)
Old Mar 24, 2023 | 08:49 AM
Cerbera7's Avatar
Default X358 starting issues (possible fueling)
Help guys, I've inherited my dad's diesel XJ with the 2.7. it's suddenly developed a starting issue. When firing up, whether it's cold or been running, it cranks over for ages before firing up. It seems better if I pump the throttle 3 or 4 time then put my foot to the floor, but still takes 7 or 8 seconds to fire. Once running it drives fine with no issues.
I've had it to a couple of garages. One says it's the high pressure fuel pump, the other says it could be the non-return valves on the end of the fuel rails.
Have any of you guys had similar problems or any idea what's going on.
Cheers guys.
Old Mar 26, 2023 | 03:51 PM
meirion1's Avatar
Try posting in the UK jaguar forum.
I don't think that there are many diesels outside the UK.
Old Mar 27, 2023 | 12:31 PM
OldKarz's Avatar
Have had nothing to do with the jag diesel however on others it is often the glow plugs not working due to relay, fuse or bad plug.
Softball60
Jun 12, 2020 04:08 PM
xjsman89
Jan 29, 2016 10:05 AM
driver safz
Jun 20, 2015 06:05 AM
Boilerpete
Dec 1, 2012 04:14 PM
gunnerman
XJ40 ( XJ81 )
Jul 12, 2010 12:20 AM
