xj 2.7 2008 engine not cranklng over
jaguar has now been of road since december still have not got it cranking,fitted new battery,checked all earths,checked feeds on starter ok,can crank engine by link in front fuse box ,have tried both sets of keys.checked all fuses, unplug and cleaned wiring loom connections
,checked feeds to ecu ok, cars as loads of fault codes coming up now,.i do have x type to use would like big jag back any advise would be welcome
i think the problem is the ecu or a relay in front fuse box? i think ecu will have to be programed in? getting just over 12 volts on starter and front fuse box.
Sounds like you need a competent tech - try N&S in Wakefield.
Independent Jaguar Specialist in Yorkshire
mystype04
Apr 11, 2019 08:46 AM
helmsteven
Jan 14, 2018 10:31 AM
SuperSport
Mar 24, 2015 10:30 AM
njk1963
Jun 24, 2011 03:01 PM
