2008 xj will not crank over new battery fitted
helmsteven (01-14-2018)
If the engine isn't cranking at all, I would certainly start by placing a voltmeter across the battery, and monitor the voltage while attempting to start the vehicle. The voltage will normally dip slightly if the battery is driving a good amount of load such as that, but I wouldn't expect it to dip below 12V in any case. By the way, precisely what new battery did you install?
It may be new however it may need charging. Also Jaguars like calcium plate technology batteries not your run of the mill lead acid despite what dealers might install.
hi will check in morning what kind of battery has been supplied
TonyD
08-04-2013 03:40 PM
