Xj6 heater motor
Old Jan 13, 2016 | 08:13 AM
Majid's Avatar
Default Xj6 heater motor
I was wondering if any one give me advice on my jag xj6 x350 2003, I change the heater motor this morning as I was getting no heat in the car plus no air con was told it was heater motor,after changing the motor, when put the heating or air con on you can hear the comes on for few seconds and cuts out straight away, any advice will be much appreciated.
Maj
Old Jan 13, 2016 | 08:56 AM
mhamilton's Avatar
More likely the blower motor module has gone bad. There's a thread on here showing how to repair it for $5 in parts, if you're electronically inclined. Otherwise they're around $200 from the dealer. Aftermarket modules are available, but most posts on this forum indicate they do not last.
You can test the motor by grounding the brown wire going to the motor (key on), which should run the fan in high speed. If that works, you're problem is with the module or elsewhere.
Old Jan 13, 2016 | 09:02 AM
Majid's Avatar
Thank you so much, I will try that on Saturday I have located the heater motor resister on eBay for £70 but want make sure is the resister first,
RobbyHughes
Mar 8, 2016 07:46 AM
JagRag
Jan 4, 2016 05:43 PM
mgm57
Dec 31, 2015 01:34 PM
RobbyHughes
UK & Eire
Dec 21, 2015 07:52 AM
snowball
Dec 18, 2015 10:07 AM
