Xj8 3.5 v8 electical problems
Old Oct 10, 2019 | 11:23 AM
Nigel Holmes's Avatar
Default Xj8 3.5 v8 electical problems
I started the car up this morning everything was fine went for a drive came home for about an hour and when I got back in the car and started it up I had lots of messages gearbox fault air suspension fault handbrake fault and the windows wouldn't work any ideas what could be wrong would be greatly appreciated x350 xj8 3.5
Thank you kindly Nigel
Old Oct 10, 2019 | 11:49 AM
roviw's Avatar
I am sure there will be a lot of others coming along to suggest their thoughts and I think most of us would probably tell you to get the battery checked or changed as that is one of the main things that will trigger lots of warning lights appearing. Most of us here have seen this issue ourselves, myself included.
Old Oct 10, 2019 | 11:55 AM
Oh OK will check that thank you kindly nigel
Old Oct 10, 2019 | 03:02 PM
Wingrider's Avatar
Battery, or the alternator not charging allowing the battery to discharge.
Old Feb 15, 2021 | 06:35 AM
Default Transmission problem
Hello and good afternoon i have a 2003 jaguar xj6 that has developed a fault but i have no lights or warnings on the dash.
1 gear shift stuck in park
2 parking sensors going off when stationary and nothing near
3 no light on j gate
4 stuck in sport mode
5 gears stick or jump in to gear
It seams like an electrical problem to me.
But the garage seams to think a transmission flush will sort it at a cost of £350+vat and they said they might have to do it twice and if that don't sort it then change the plates.
I've asked them to check the fuse box in the engine bay and check the solenoid in the transmission but they don't want to listen and telling me it doesn't have a solenoid in there.
A little help would be appreciated guys
Thank you kindly nigel
Old Feb 16, 2021 | 02:29 PM
JagV8's Avatar
I would recommend not posting the same thing more than once. Mods may ban you...
six6rider
Feb 5, 2018 09:09 AM
Jagman760
Jun 12, 2014 09:40 AM
les
Apr 29, 2014 06:33 AM
