XJ8 Navigation Bypass
Old Aug 14, 2007 | 07:24 PM
jag_genius's Avatar
Default RE: XJ8 Navigation Bypass
there is definitely no wiring bypass at all .. the nav goes from a SCP network then to the gateway of the instument pack then the instrument pack via CAN network to the abs for vehicle speed.and i dont think there is any programming to change that .. unless engineers can..
Old May 2, 2011 | 02:47 PM
Radjag's Avatar
Default XJ8 Navigation Bypass
The updated Navteq software allows this feature while the car is in motion. Posted from another string.
Old May 2, 2011 | 03:33 PM
roviw's Avatar
In the Uk, I bought a disc from Jaguar which was the 2010 disc for my 2003 car, when installed it updated the firm wear to allow operation when the car is in motion, ask your dealers over there if the same will work for you.
Besrt of luck.
Old May 2, 2011 | 03:57 PM
kthrash's Avatar
Originally Posted by Radjag
The updated Navteq software allows this feature will the car is in motion.
I have the latest disc 2009-2010 and it does not allow for this feature.. what disc do you have?
Old May 2, 2011 | 04:39 PM
jahummer's Avatar
Same here. Does not work. I think this is a US DOT requirement, perhaps?
Old May 2, 2011 | 08:39 PM
mckellyb's Avatar
FWIW, in my wife's 2002 RX300, there is a hack in one of the screens where, if you touch the top-left, the bottom-left, the top-left, the bottom-left, then the bottom-right, it unlocks so you can use it in-motion. It must be done at every start, however.
Idiotic.
I've gotten in the habit of doing this when I start the car, 'cause there's no reason she can't use the system while we're crawling along, or whatever....
donald ebanks
Sep 30, 2015 07:08 PM
freddieg
VENDOR 'For Sale' Classifieds
Sep 29, 2015 07:13 PM
magmedia
Sep 28, 2015 09:49 PM
SoCalJagS
Sep 27, 2015 09:20 AM
