XJR The Oddest Noise - Driving Me Nuts! -FIXED
Old Nov 16, 2011 | 10:10 AM
DanielCR's Avatar
Default XJR The Oddest Noise - Driving Me Nuts! -FIXED
Hello! I'm hoping that someone has the answer for me or perhaps an idea. There is a noise the mechanics cant find it because they don't have the the time to drive the car.
2004 XJR 90,000KM (56,000mi)
About the noise:
-Only when the car is in motion
-Doesn't change/modulate with REVs or Speed
-Sounds like a plastic bag is being dragged out side or a deep low hiss
-Seems to start once the car has reached temperature
-Sounds a bit like Morse code if you were to do it with a plastic bag out the window.
-It is NOT wind noise and sounds like it is on the left side of the engine/exhaust.
-I can't tell if it is the back or the front
-Doesn't go away when the car is shifted into Neutral
-Doesn't changed when you break ... only when you stop.
-Doesn't do it when parked or if the car is still even if you are Revving the engine.
I'm at my whits end! It sounds like a loud and intermittent and doesn't respond to speed or revs.
Any ideas? Exhaust? Belts/Bearings?
Thanks!!!
Old Nov 16, 2011 | 10:14 AM
DanielCR's Avatar
Forget the plastic bag... It sounds like a belt but rather than a squeal is is more of a gushing air noise.
Old Nov 16, 2011 | 11:00 AM
Casper's Avatar
Gushing air noise maybe air suspension pump or venting the air/pressure from the pump?
Old Nov 16, 2011 | 03:40 PM
DanielCR's Avatar
Hi Casper, I must say I don't think it is the air pump. When I'm at a stop the pump sometimes raises the car up and I can't hear a thing...
Old Nov 16, 2011 | 03:42 PM
Casper's Avatar
Mine have some of the noise when stepping on the brake while in motion and the car seems to vent some pressure air out and it's coming out from the left side of the front too. It sounds like blow off valve from turbo car. It's not the pump that makes the sound but it's some form of pressure relief from the air shock or something I guess.
Old Nov 22, 2011 | 11:16 AM
DanielCR's Avatar
Update: I removed the two fuses for the air suspension and the noise is still there... I drove the car to 60kph and put it in neutral and turned off the ignition while the car was moving and the noise was still there... Any thoughts?!?
Old Nov 22, 2011 | 11:38 AM
user 2029223's Avatar
Banned
You could have a leak in the power brake vacuum booster. There is an engine vacuum hose that connects to it and an internal air bladder, either of which could account for the noise.
Old Nov 23, 2011 | 08:37 AM
oldmots's Avatar
You might have a loose caliper rubbing the disk , check the brakes for this or a rock in a caliper.
Old Nov 23, 2011 | 10:54 AM
DanielCR's Avatar
Thanks for the breaks idea. I'm confident it isn't the breaks because the noise is there even if the breaks are depressed. I thought it could be the park break caliper but it doesn't seem to be.
Old Nov 28, 2011 | 04:42 PM
DanielCR's Avatar
Could the noise be some sort of low break pad warning? The breaks sound good when applied but perhaps there is some sort of "warning devise" that makes a constant grinding noise while driving?
Old Nov 28, 2011 | 04:53 PM
Banned
You can get a vacuum leak in this area even without brakes being applied. Start the engine, open the hood, remove master cylinder compartment cover and get your ear down close. Worth a try says I.
quote=DanielCR;432055]Thanks for the breaks idea. I'm confident it isn't the breaks because the noise is there even if the breaks are depressed. I thought it could be the park break caliper but it doesn't seem to be.[/quote]
Old Nov 29, 2011 | 03:54 PM
oldmots's Avatar
If the caliper is loose and rubbing the disk, the brakes will still work but the caliper body will continue to rub the disk and make the noise until both bolts fall out! Then it will be a new experience as it rides forward until the hose breaks and it falls off!
Old Nov 29, 2011 | 03:57 PM
Road_King's Avatar
...me thinks, it is a vacuum leak (disconnected or broken hose). These are extremely hard to find.
Good Luck!
Old Nov 29, 2011 | 04:53 PM
SuperTrav's Avatar
I agree Road King.
Old Feb 3, 2012 | 11:05 AM
DanielCR's Avatar
Default Problem Solved
I hope this helps anyone with the same issue. It is finally fixed! It turns out that the noise came from a plastic dust ring that came lose from the drive shaft bearing. Apparently it was spinning & rubbing and making the noise. The mechanic removed it and all is well.
Old Feb 4, 2012 | 03:47 AM
Cadillac's Avatar
Good to see it was fixed , thanks for your update
BrentGardner
29
Dec 16, 2024 12:13 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
allenman85
May 10, 2021 03:11 PM
Fraser Mitchell
Oct 1, 2015 04:06 AM
Sshenton1975
Aug 30, 2015 09:29 AM
