ZF Metal Pan Upgrade?
Old Nov 21, 2013 | 04:50 PM
Beavis's Avatar
Default ZF Metal Pan Upgrade?
Hi all,
Now i've got my car back I've been taking a look at doing a big service including the gearbox pan and filter change.
My car has just clocked 64k miles,and I think a service may fix a couple of issues i'm starting to see in the transmission.
Now, as the title suggests I've come across a metal pan version with a changeable filter inside (listed as OEM metal transmission Sump modification kit ZF 6HP26), and im wondering if this would be a worthwhile upgrade on my Super V8. I assume the heat dissipation properties of the metal will aid with cooling the oil - but sufficiently to be worthwhile? My long term view will be to upgrade to the twin screw supercharger, so what do we think about the metal pan?
Old Nov 21, 2013 | 08:45 PM
iBike's Avatar
Wish I'd known of that two transmission services ago. I'm going to have to look into it, myself.
I do hope that there are some knowledgeable replies.
Old Nov 22, 2013 | 02:59 AM
JagV8's Avatar
You don't necessarily want it to cool the oil, that's what the existing cooler does. The oil is intended to be within set limits.
I don't see why you couldn't fit the metal pan either way, though. Costs more, as I recall.
Old Nov 22, 2013 | 08:41 AM
cjd's Avatar
cjd
The tranny has an oil cooler...and the pan is mostly covered by the undertray anyway, so not likely to get a whole lotta extra cooling. So, I don't see any performance reason to change it. If you like the way it looks, then that's just as good of a reason as any.
Old Nov 22, 2013 | 12:32 PM
veffremov's Avatar
The plastic pans warp and start to leak. I'm on my second in 4 years. Maybe this metal one can last longer. Keep us posted.
Old Nov 25, 2013 | 10:38 PM
Anders Hansen's Avatar
Please search my post in general tech, it has all needed info incl. part # for pan/gasket/filter.
Search: ZF6HP26 steel pan conversion.
MrWhite
19
Jun 14, 2022 07:49 PM
Joachim1167
Nov 7, 2020 09:18 PM
42Ajd
Sep 26, 2015 07:04 PM
