1995 jag starts misfire and dies
Old Aug 19, 2013 | 08:11 PM
Big-D's Avatar
Originally Posted by sleekjag12
uh-oh. New coils. There have been several reported problems with new aftermarket coils causing misfiring and other strange symptoms. Sorry to dig that up, doug!
The sensor near the throttle body (on top) with 4 wires is the iac (idle air control). Unplugged = open = more air though throttle body, probably higher idle rpm. Plug it in and it dies = bad iac, closing off air supply. Or, very dirty throttle body with iac passage blocked too much. However, in theory the iac should compensate for that, by opening more to keep the rpm in range.
check out iac started run fine until warm up and sometimes it dies before warm up. I unplugged iac nothing happened . Plugged it back in nothing happened run the same run smooth. P1775 ,p1790 codes. When it dies the battery light and engine light comes on. I also had 1 o2 sensor unplugged nothing happened run smooth. When it got to just before normal temp it would die and start up again run smooth and die.
Old Aug 19, 2013 | 08:27 PM
Big-D's Avatar
i just checked the two front oxy SENSORS AND SIGNAL WIRE SWITCHES ON AND OFF WHEN WARM EVERY FEW SECONDS AND THE HEATERS NEVER COME ON .
the signal will fluctuate between 0 and 3v on/ off
Old Aug 19, 2013 | 08:30 PM
Big-D's Avatar
Originally Posted by Doug
Find a schematic labled "AJ16 NA Federal Engine Management"
I think you're looking at an "ROW"--Rest of World---schematic
I MUST HAVE THE RIGHT ONE.
Old Aug 19, 2013 | 08:33 PM
Big-D's Avatar
Fed ex hasn't delivered the iac .
Old Aug 19, 2013 | 08:39 PM
Big-D's Avatar
Fedex finally gave a response they gave it to us postal to deliver it tomorrow. It was here in town this morning but they turned it over to us postal service . It took 8 days to get here from berlin wi. In usa
Old Aug 19, 2013 | 09:53 PM
Big-D's Avatar
Are you referring to the iac next to throttle body with 4 pins
Old Oct 19, 2013 | 02:34 AM
Big-D's Avatar
i dont know why tps is getting spikes to like 64 from 12 at steady throttle. is this tps defective or something else triggering it. got this reading by graphing tps on obd2 it spikes to 64 only when it misfires. any ideas this is using Acton cp-9580 obd2 otherwise it is a flat line except on acceleration.
allenman85
May 10, 2021 03:11 PM
Drew2006
Nov 24, 2015 11:14 AM
alpecsa
Sep 7, 2015 11:55 AM
tberg
Sep 7, 2015 07:32 AM
1964Daimler
Sep 2, 2015 11:41 PM
