1995 x300 cranks no start
Old Oct 26, 2022 | 07:07 PM
RodBaker's Avatar
Default 1995 x300 cranks no start
hi all
i am trying to get this jag to run for a mate .
it just failed to start one morning, on investigation it had no signal from the crank angle sensor as the tacho showed no movement while cranking .
i have just replaced the CAS and it started first try drove it around for ten stopped n started a few times all seemed good . next morning no start ,tacho shows it cranking at approx 300 revs fuel pump can be heard running .
not sure what to do.
Old Oct 26, 2022 | 09:28 PM
Parker 7's Avatar
The CKPS was the correct choice but the new one is probably bad out of stock
Thinking / editing
the first 3 seconds of fuel pump operation is triggered by the ignition switch
The second turn back on for the duration of your drive is the CKPS seeing engine rotation / safety design
You can jumper the fuel pump relay to keep the fuel pump running at all times but this will drain the battery with the keys in your pocket
Pics coming
Your power sockets are 3 and 5 or 30 and 87
You'll have to use heavy gauge wire with blade type connectors for better connection , the auto parts store counter can sometimes make one up for you
The CKPS CEL code P0335 will not always appear in its different modes of usage like fuel pump enable
Andy Roo
Aug 12, 2016 10:50 PM
Jetze Mellema
Aug 6, 2013 10:13 PM
the barder
Jun 29, 2011 07:06 PM
Peter Schuptar
Feb 20, 2010 06:15 AM
Rocafella117
Sep 29, 2009 12:53 PM
