1995 xj6 gauge panel light show
Old Jan 22, 2012 | 07:08 AM
uuuanut's Avatar
Default 1995 xj6 gauge panel light show
Newbie here. I have a 1995 xj6 and the gauge panel yesterday went crazy. All of the lights on the panel flash on and off while the gauges cycle back and fourth. The car runs fine while this happens just don't need the light show. Any help would be appreciated.
Old Jan 22, 2012 | 10:29 AM
Doug's Avatar
(At least) one of your ignition coils is faulty.
I went thru the same thing. Strange, huh? I never would've guessed it had it not been for help from others here.
Anyhow, remove the coil cover and run the engine in the dark. If you see a light show in the opaque potting material of one of the coils, that's the one causing the problem.
Old Jan 23, 2012 | 04:17 AM
uuuanut's Avatar
Thanx I will give it a try......
Old Jan 26, 2012 | 05:00 AM
uuuanut's Avatar
Default coil pack
Hey Doug checked the coil last night and you were right. Thank you for your help and being the only one to respond.
Ed
Shawn Svacha
Nov 4, 2019 02:47 PM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
OkieTim
Sep 2, 2015 12:48 PM
