1996 Jaguar x300 (3.2 left handle type) Auto door lock not working
Old Apr 28, 2023 | 06:17 PM
jdhwan80's Avatar
Default 1996 Jaguar x300 (3.2 left handle type) Auto door lock not working
트렁크를 포함한 모든 도어는 리모컨으로 열 수 없습니다.
차량 내부의 트렁크 스위치와 센터 콘솔의 잠금 버튼도 작동하지 않습니다.
slcm/보안퓨즈/드라이버 와이어 도어 액추에이터를 모두 확인하고 리모콘 건전지도 교체했는데 신호가 나오지 않습니다.
Reader / Exciter ecu만 확인할 수 없습니다. ECU가 어디에 있는지 찾을 수 없습니다. 찾을 수 없습니다.
ECU가 없는 모델이 있습니까?
뭐가 문제인지 도와주세요
Old Apr 28, 2023 | 08:23 PM
Parker 7's Avatar
All doors, including the trunk, cannot be opened with the remote control.
The trunk switch inside the car and the lock button on the center console also do not work.
I checked all the SLCM/security fuse/driver wire door actuators and also replaced the remote control battery, but there is no signal.
Only the Reader / Exciter ecu cannot be checked. I can't find where the ECU is. Not found.
Are there any models without an ECU?
Please help me what is wrong
Old Apr 28, 2023 | 08:28 PM
Parker 7's Avatar
The security lock control module is located fwd of the trunk car's left hinge a little inboard of the fuel fill cap
You will have to remove the fwd facing trunk panel
The SLCM will be mounted at a slight angle with 4 connectors that are grouped to look like 1 long one
Do not remove connectors without removing positive battery cable
Had any heavy rain lately as there is a drain that cloggs and the SLCM connectors may have got wet
There are a few TSBs to see starting with section 18
315 or 433 hz ?
JagRepair.com - Jaguar Repair Information Resource
Old Apr 28, 2023 | 10:42 PM
Parker 7's Avatar
Fuse # 4 trunk fuse box
Are 2 different FOBs doing the same thing , if so points away from being a FOB issue
Old Apr 29, 2023 | 08:18 AM
Vee's Avatar
Vee
I would ask "does the car lock and unlock manually, each door and trunk, using only the key?"
I'm not intimately familiar with the x300, but can you perform an "all doors lock" using the key? I'd ask if that is working as well...withOUT using the FOB.
I would start by unplugging and replugging back in the door lock relay, IF the x300 has one similar to the XJS. The XJS uses DAC4862 and is problematic on both my 96 cars. Unplugging it and plugging it back in always restores it.
If not, the Security ECU (which I know the x300 does have) might be damaged? I haven't read about that being a common problem though.
Lastly, the remote locking feature getting wonky is usually indicative of a failing battery for the XJS I have owned. How old is the battery?
Old Apr 29, 2023 | 10:35 AM
Parker 7's Avatar
The Fob batteries can easily be put in backwards and best to use a high quality brand battery
Vee is mentioning the main car battery wich is important also in the security system
With a 315 hz system you have many external to the security lock control moule relays located is this pic
With the later 433 system you don't have these relays
See page 28 , left heelboard relay area
www.jagrepair.com/images/AutoRepairPhotos/jagxj1996.pdf
Pic coming
Before sourcing another SLCM a cheaper try is the micro switches in the FOB as they are available on E - bay
micro switch repair remote alarm key fob jaguar XJ6 XJ12 XJR X300 saab 9000 900 | eBay
and
fits Jaguar remote key fob X300 XJ6 XJ12 - 2 Silicone Repair key Buttons (1SET) | eBay
Davidvdm
Nov 18, 2022 12:55 PM
Len Apcar
Nov 18, 2019 06:06 PM
Jaglady96
Apr 22, 2019 07:33 AM
NavyBlue
Jul 13, 2018 05:05 PM
Tec Nine
Apr 13, 2011 04:03 PM
