1996 VDP Rear End Noise
Old Nov 14, 2019 | 01:22 PM
Stayne's Avatar
Default 1996 VDP Rear End Noise
I have been hearing a rotational mild clunk or click in the rear and most predominant at around 40 mph. I put the car on jacks and put it in neutral to try and demonstrate and replicate. Video link is below. Any thoughts?
Old Nov 16, 2019 | 05:42 AM
countyjag's Avatar
Wheel bearing?
Old Nov 16, 2019 | 06:25 AM
Stu Jags's Avatar
UJ clacking exhaust ?
Old Nov 16, 2019 | 11:13 AM
countyjag's Avatar
UJ is a possibility, but the UJ web bearings aren't rotating at that speed
Old Nov 16, 2019 | 11:58 AM
Doug's Avatar
My guess is wheel bearings or spider gears in the differential.
Get under the car and put your ear close to the differential while a helper does the spinning. Is the noise louder at the diff?
The noise is rather loud. If a wheel bearing, it's pretty well shot, and I'd think you should be able to feel some roughness right at the hub.
Wheel bearing failures and diff failures are not uncommon on X300s
Disconnecting the half-shaft would help isolate the problem but doing so isn't a 5 minute thing
Francisco Farrera
Oct 18, 2019 12:47 PM
Kopi
Jan 4, 2018 09:54 AM
NCJagman
Apr 15, 2016 12:40 AM
wfd
Feb 23, 2011 05:34 PM
